FPV disabled my camera. Please help.
SaltyPeanut
I have recently bought a sj6 legend on Amazon, and was playing around with the settings. I saw FPV and I enabled it. The device turned off, and. I tried turning it on again, but it would just immediately turn off. I don't have a mini HDMI or DV cord, and I was wondering how I could disable FPV outside the settings.
D
Deleted member 24437
Guest
Have you tried pluggingUSB into your CPU and looked for the cam turning on as other SJCams?
One more obvious question ,did you charge the battery first? All the action cam batteries I've bought needed charging.
S
SaltyPeanut
Yes I have charged it, ive had it for a week now, and when I plug it to a PC, it doesn't show that it's connected
SnowCam
Phuket
Thailand
Did you resolve the problem. I recently accidentally pressed on the FPV and ran into the same problem as you exactly. I connected the camera to notebook and the notebook can't detect the memory card, which I was just open the file via usb connection a few hrs ago. Any solution will be very appreciated. I was on a trip and suddenly can't use the cam.
TonyCams
China
I will check on this issue for you..
TonyCams
China
I am checking into this for you
TonyCams
China
Please try upgrading to this firmware: SJ6 firmware
TonyCams
China
TonyCams
China
would it be possible that because I also accidentally formatted the microcard?
maybe it is a problem with the car itself.... really not sure...
TonyCams SJ6 6
TonyCams SJ6 27
