I connected two 8-foot long USB cables into a 12volt to 5 volt converter like the one seen below and spliced that into an add-a-fuse which I ran to my fuse panel. Using two 3amp fuses in the add-a-fuse. Am using Mobius for both front and rear cams.what cameras, what power supplies?
Ok, thank you. My car is a 2004 VW Jetta sedan. There is a fuse location dedicated to the rear wiper motor which my car does not have because it is a sedan not a wagon. There was no fuse inserted at that location so that is where I placed the add-a-fuse, but only the rear cam was turning on(the rear cam fuse was in the piggyback slot on the add-a-fuse). There are a few open fuse locations, but they are not set up, so I don't know what I am going to do. Thanks for your help.that's just a single power supply so one fuse tap, if tapping a circuit used for something else the original rating fuse value should be used for the existing circuit
Could be a bad soldering job on the wires inside the converter, or even a bad USB cable or plug so swapping cameras and cables would definitely be a good troubleshooting procedure.
possible the power supply has over voltage on one side and the protection circuit in the camera is preventing it from starting also
I have complete faith in mine:I don't trust those cheap power supplies, they're cheap for a reason, not just because the manufacturers are nice people
Waterproof, Moistureproof, Earthquake Proof
OK, thank you. I'm deciding whether to use this kind of box style power supply or a combination of hard wired 12V socket connected to the add-a-fuse on one side and a plugged 12V to 5V/USB "stick" supplied with the dash cam. Could the "box style" power supply be electrically any better than the supplied "plug-in stick"? (Thinking of e.g. higher quality hybrid or better elaborated circuitry, at least just because of having "more space" available.) I cannot find too many hard wiring kits and all look or are cheap. But do these need to be expensive with 1.5A max. current?All of the "switching power supplies" like this generate interference. Some cams handle that better than others and sometimes placement and cable routing can minimize that acceptably. But sometimes the interference cannot be easily solved if at all, and the only way to know is to research to find of others with that car/cam/PS combination have reported problems or to try it yourself. Cams and GPS devices themselves generate interference similarly so nobody can guarantee against this.
There are some things you can do to minimize the risks: keeping distance between the devices, not running cables parallel or near to other cables and wiring, not having anything near antennas and their cabling, and adding snap-on ferrite chokes to offending wiring/cables. All you can really do is try- you might get lucky!
