Old shippo
Hi everyone. First post, so go gentle
Ok. I managed to hard-wire the camera into the wife's car easily enough. It comes on when the ignition is switched on, and turns off when the ignition is turned off. Great, however, re the fuse tap. I see on the instructions that you have to piggyback the removed fuse into the fuse tap, but the removed fuse doesn't fit! It's wide enough, but the silver prongs aren't long enough to slide in!
Am I getting confused here? does the removed fuse have to go back? I'm only saying that because as you know the fuse tap comes with a fuse in it. WIl this one fuse run the camera and whatever fuse I removed? By the way - the car is a 66 plate Honda Jazz.
As for the memory card. Reading up on the camera and what type of card it needs prior to purchase. I bought a Samsung 64GB micro SD card U3. As soon as I fired up the webcam I got the error "SD card is less than U3, Please replace SD Card" !!!!!
On googling the particular error, it seem this issue is all to do with the modular rear plug-in camera. I went outside to the car and unplugged the rear camera and bingo, the main camera works fine!
Just a thought before I go. I wonder if reducing the resolution to 1080p would get rid of the "SD card is less than U3, Please replace SD Card"
Any suggestions would be very much appreciated.
Thank you.
Thank you.
