G1W (Unsure what model) - Files missing & potential firmware upgrade.
dishlex
Likes
#1
Good evening,
I have a G1W, but I am unsure if it is a G1WH or G1W.
I have just tried to update the firmware with the multiple G1WH firmware available but it didn't seem to recognise it, so perhaps it is a standard G1W.
The current firmware listed is 2016.0728.11am, however a google result suggests it is a G1W-CB, so I will need to try that firmware.
Anyways, I have noticed that whenever I take the camera out of the car after recording something interesting, the file I want is generally missing. Whereas the video before and after it is always there.
Apparently if I turn motion detection off, this may resolve the issue? I believe it is already off, but I have double checked and made sure it is off, and also disabled the G-Sensor.
The card in use is a Samsung 32GB SD card, if that has any bearing on recording issues.
I am just wondering if a firmware update may resolve this issue, or if this is an issue that people are familiar with at all?
Thank you.
SawMaster
Likes
3,257
SC
Mobius, G1W-S, G1W-HC, WR-1, G1W clone, B1W
#2
You seem to be on the correct path with settings and card :) Perhaps it is a firmware issue, and indeed here are different ones for the -C and the -H versions. Without knowing what the original firmware was it's anyone;s guess for what you need. Contact the seller and see if they can send you the original firmware, then you will have a better chance at finding compatible upgrades. At worst you'll have a reliably working cam again ;)
J G1WX 10
Similar threads
