G1WH problem with G-Sensor - on any software DOD LS388W, GT300W, G1WH - 2014.0108
frytek84
Poland
Hi.
I've got G1WH updated software to DOD LS388W.
Problem is when G-Sensor is set up Low or Medium or High is start recording with lock video - each video = card full and not recording with loop.
When i turn OFF G-Sensor is recording without locking (that is ok).
I try also software from Shadow GT300W - 1306180-SC-2 - This same.
When i try on G1WH - 2014.0108 software and set up G-Sensor Low or Medium or High doesn't lock video at all, even when i hit Cam.
Motion detection: OFF
Card is ADATA Micro SD HC 32GB Class10
Why is recording any video as Lock? On any settings (except OFF).
Difference in operation is probably a result of firmware (software) being not compatible with your specific camera. G1W-H is a style of camera produced by many manufactures. Even though the outside looks the same the internals can be different.
The G-sensor on my G1W-H requires a fairly significant impact before it will lock a file. Just hitting it with my finger is not enough.
What can i do now? I try 3 software's - no difference. How can i fix this?
I don't want drive and in a accident file will be deleted by recording in loop or driving with G-sensor all the time OFF
Yes, it does. I try 4 different software's and still has got problem with recording
Great. Also i checked inside and should be battery 1500mAh and i've got 130mAh.
Where is best to buy? Can i buy somewhere that G1WH with DOD LS388W software on it?
turn the camera 360 degrees rather than hit it with your hand or drop it on solid surface gently !
Can that software update's destroy G-sensor?
Because when i turn On camera first time when arrived and tested everything was fine, after first software update start to be problems with g-sensor.
petepete i'll do when my new camera will arrive. Maybe that knocking by hand destroy G-sensor. Anybody know where exactly is that sensor on the motherboard?
E G1WX 11
karas2002 G1WX 1
D G1WX 24
A G1WX 11
Makke G1WX 13
