G90 VS Mini 0805
old4570
Front: 70MAI , Ausdom A261, Mini 0826 , Rear: A118c
Ambarella A7LA70
170 degree ultra wide angle lens
Battery type: Built-in
Capacity : 90mAh lithium battery
Decode Format: H.264
Video Format: MOV
GPS
Lane detection
Ambarella A7LA50
120 degree wide angle lens
Capacity : 320 mAh
Video Format: MOV
GPS
Lane detection
Both cameras are featured similarly , priced very close to each other .
Both cameras dont deal with flare / reflection very well .
The G90 GPS function is rather slow to fire up .
The G90 mount is a little flimsy and sometimes I notice some extra Vibration in the video
The G90 microphone is some what weak , so I leave it off
The Mini 0805 microphone is relatively ok , so I have left it on .
The Mini 0805 screen flickers a lot
I have two comparison video's , full frame HD and one side by side ( ok one on top the other ) .
Night time video added !
UPDATE ( 25-8-2015 )
I have had both cams for a while now :
0805 -
Wow the mic turned off on its own ?
The GPS is getting funky ( not working properly )
G90 -
That suction cup really bites , so many times now I have gone to the car and found the G90 dangling by the USB and GPS cables .. ( This is seriously bad ju ju )
So in hindsight , would I buy either = No , I would look else where ..
The G90 falling off the windshield constantly ( Very Bad )
The 0805 seeming to have issues , especially with the GPS 10 ( again very bad )
Honestly , you may wish to look elsewhere for a dashcam ..
Update 26-08-2015
0805-
Looks like the GPS has stopped working :
Update 27-08-2015
0805-
Replaced the USB cable - GPS is back to being flaky
Is it a USB cable issue
Is it a mount issue
Or is it a battery issue ( clock resets to 00.00 )
Im starting to lean toward the Mini 0805 being a regretful purchase
G90-
I used some Vaseline on the suction cup and the G90 has not fallen since ...
Update 15-9-2015
G90-
I have remounted the GPS receiver on a suction cup cam mount so that it will pick up GPS Signals better , so far it look to work ..
I will have to check the footage and see if the GPS lag has improved ..
The time to pick up satellites has improved .
Im also testing a 64gig card in the G90 ..
