Garmin 55 DIY Power
gus13
Scotland
Hi
sorry if these have been asked a few times, i had a look through but couldn't see a full answer:
1. Can the DC 55 be powered using the USB cable supplied, i.e. from a USB phone charger etc. so i can test/setup the unit while at home. When i plug into PC it goes into PC mode. I am happy to use the supplied Garmin USB cable, but every charger i try, i get the Please use Garmin Cable error - i AM using a Garmin cable?
2. I want to hardwire to car fuse box and use a double fuse point to jumper. I do not want to cut the supplied car charge cable. I am happy to solder and wire up. What is the best approach to ensure my new cabling is supported by the DC55, i do not want Parking mode.
thanks
Gus
Looks like this should work for you:
