Garmin 67W SD Card Question
JLA956
Texas
This is my first Dash Cam and I was wondering if I should upgrade to a larger SD card than the 16GB one that came with it? My understanding is that with a larger card you have fewer read/write cycles so the card should last a lot longer. Again, this is my first dash cam so that might not even be a problem, and since they only included a 16GB card it might be all that's needed. If you do recommend a larger SD card, then what brand/model do you suggest? The specs on the 67W are up to 256GB Class 10 or higher. TIA for your help.
I wouldn't go for less than 64GB (High Endurance)
128G will be a good choice, if your dash cam is 4K , 16G will not work at all.
