RonnieJM
I have two Garmin Mini 2 dash cams in my car.
The front camera operates correctly.
The rear camera takes about four minutes after the car ignition is switched on to start recording.
During this time the recording light shows green, (the manual says this means the SD card is being formatted)
(I have tried three 64Gb SD cards in the camera, with the same result, these cards all work fine in the front camera.)
After this time the the recording light turns red, the camera beeps and the camera records normally, until the next time the car is turned off and then back on
when the process is repeated.
This is not a huge problem, but I do miss the first four minutes of every journey.
I can't be absolutely sure on this point but I think I started noticing this around the same time as the last Garmin software update,
around early March 2023.
Nothing in the manual about this and contacting Garmin direct seems difficult/impossible here in the UK
Any suggestions would be helpful.
