Gearbest Dome G90 Dashcam with Ambarella A7LA30 Review
Sunny
Colorado
More than I can review. ;)
Just received G90 dashcam from Gearbest.
With expedited shipping, it was delivered very quickly.
Less than 5 days from Singapore to USA via Hongkong counting weekend. Kudos to Karen @ gearbest.
Here is product link: http://www.gearbest.com/car-dvr/pp_33655.html
EDIT: Now it's on sale @ $69.98 after coupon code BL950.
http://dashcamtalk.com/forum/threads/gearbest-com-has-g90-bl950-for-69-98-after-coupon.6729/
The actual product box was inside a brown cardboard box that was in a DHL packet.
Came in perfect condition except some scuffs on the external DHL plastic packet that is expected.
The box doesn't mention G90 anywhere on it.
It just has Car Camcorder and specifications printed.
It came with the dash cam, mount, car charger and usb cable.
I'll add pictures of the product/box later.
I had it in the car today morning with HDR off.
It has the same audio issue as other G90's though.
C600 has very low volume but I can clearly hear/understand NPR radio on it but G90 has breaks/vibrations on the sound and very hard to understand anything.
It's like when you record a video outdoors in the wind.
I have to get better firmware and see how much difference that makes in audio.
It is not a fair comparison against my C600 but man what a difference!
Colors are more natural, sharp and lots more detail compared to washed out colors in C600.
Even when the Sun is right in front, G90 is very clean and can read street signs and names easily.
It's still hard to read license plate in front due to dashboard reflection in that area and due to the Sunlight shining on the windshield imperfections (I have many sand sparkles on windshield that shines on direct light).
When the Sun is on the right, G90 has more dashboard reflection on that side than the C600.
May be due to wider FOV.
Polarizing filter should clean it.
Also, it is with HDR OFF. I'll test with HDR ON and see how that handles direct sunlight.
BTW, there is no indication of HDR off or on on the file properties that I can find so need to remember when I had it on and when I had it off. Hmmm...
Will post videos later after driving around different conditions.
I realized that I had it pointed little higher so need to point it down.
Here are few screenshots from windows media player.
My work monitor is not 1080p so it may not be as clear as if I grab frame at full resolution.
G90: Mountains, shrubs and trees are clean, clear and natural color just like I see.
20140722-g90-screenshot-1-png.6340
C600:
20140722-c600-screenshot-1-png.6346
G90: Handles sunlight much better.
20140722-g90-screenshot-2-png.6341
C600:
20140722-c600-screenshot-2-png.6347
G90: Handles sunlight much better. The green signboard is green and can make out something is written there.
20140722-g90-screenshot-3-png.6342
C600: Green signboard looks dark and no writings can be seen on C600.
20140722-c600-screenshot-3-png.6348
G90: Can read writings on the far lane truck easily.
20140722-g90-screenshot-4-png.6343
C600: No can do.
20140722-c600-screenshot-4-png.6349
G90: Can read license plate on the left.
20140722-g90-screenshot-5-png.6344
C600: Not easy to figure out license plate.
20140722-c600-screenshot-5-png.6350
It's looking very good.
I'm still waiting on G1WH that I ordered from Gearbest before the G90 but without expedited shipping so it's taking its time.
I'll do a comparison against G1WH once it gets here.
More later...
Same screenshots as above...
20140722-G90-Screenshot-1.png 20140722-G90-Screenshot-2.png 20140722-G90-Screenshot-3.png 20140722-G90-Screenshot-4.png 20140722-G90-Screenshot-5.png 20140722-C600-Screenshot-1.png 20140722-C600-Screenshot-2.png 20140722-C600-Screenshot-3.png 20140722-C600-Screenshot-4.png 20140722-C600-Screenshot-5.png
One more screenshot...
G90: Can read street sign easily. Buildings and trees on the left and far right are very crisp and natural.
C600:
hi Sunny, tks for making the comparisions between G90 and C600.
Although it is not a fair comparison, one is Ambarella A7, one is NTK96220, but this make people easily to understand
what is high-end dash cam, what is A7, what is G90. ;)
Regarding the sound, as mentioned before, it is the problem from the first batch of mass production, what we can do is to improve it a bit better by firmward,
cannot 100% solve it. But from the second batch MP, there is no such problem.
I'll upload videos from second batch soon.
Okay so that brings this question.
Is it possible to replace the faulty mic with the one that works better?
Also, it doesn't stay on battery power.
As soon as it starts up, it displays 'Goodbye' and shuts down.
Is it something with menu settings?
Here is my firmware. It doesn't say anything so not sure what it has.
It could be initial or somewhat later version.
https://dashcamtalk.com/forum/attachments/20140723_072342-jpg.6371/
G90 vs G1WH. --> winner is easily G90.
With initial firmware:
Filename is by date time in G90 (2014-07-24-08-48-19) while G1WH files just have number (12430015).
Filesize for 3 minute clips: G90 @ 348mb; G1WH @ 282mb.
Total Bit rate: G90 @ 15378kbps; G1WH @ 12389kbps.
Data rate: G90 @ 14992kbps; G1WH @ 11877kbps.
Audio bit rate: G90 @ 385kbps; G1WH @ 512kbps.
Audio Sample rate: G90 @ 48kHz; G1WH @ 32kHz.
Physical size:
G1WH is much wider than the G90.
20140724_085245-jpg.6401
Sorry for terrible reflection.
20140724_085413-jpg.6387
Charger is exactly same for both.
The two on the right.
20140724_085229-jpg.6385
Focus:
G90 has uniform sharp and crisp focus while G1WH has soft focus on the lower right area.
Colors:
G90 all the way. Very natural, very bright and crisp.
G1WH looks slightly washed out in comparison.
FOV: G90 has more in the view. Objects in G1WH look closer as it doesn't have as wide angle as G90.
Details:
G90 has much more details than G1WH.
If you check screenshots, road and tree etc... patterns are very crisp and sharp in G90 compared to G1WH.
Against sunlight:
G90 handles sunlight better.
Green signboards appear green even with the Sun in front in G90 while G1WH washes the color out and makes it very dark.
Audio: G1WH has smooth audio while G90 has choppy audio spikes.
Conclusion: G90 is very natural, crisp and clear video.
Except in audio, everything goes to G90.
Looks like Ambarella A7 is clearly better than NT96650.
Screenshots:
G90:
20140724-g90-screenshot-1-png.6396
G1WH:
20140724-g1wh-screenshot-1-png.6390
G90:
20140724-g90-screenshot-2-png.6397
G1WH:
20140724-g1wh-screenshot-2-png.6393
G90:
20140724-g90-screenshot-32-png.6398
G1WH:
20140724-g1wh-screenshot-32-png.6400
Video samples:
I haven't spent time to combine videos in one so they are individual clips.
G90:
G1WH:
G90:
G1WH:
Night-time (low light):
I haven't had a chance to take night videos yet so that'll be in few days to come.
Few more screenshots: I had to reduce size to upload here so that may have degraded some quality.
G90:
20140724-g90-screenshot-3-wmp-png.6406
G1WH:
20140724-g1wh-screenshot-3-wmp-png.6402
G90:
20140724-g90-screenshot-4-png.6407
G1WH:
20140724-g1wh-screenshot-4-png.6403
G90:
20140724-g90-screenshot-5-png.6408
G1WH:
20140724-g1wh-screenshot-5-png.6410
G90:
20140724-g90-screenshot-6-png.6409
G1WH:
20140724-g1wh-screenshot-6-png.6405
Do you have any night video and sunny to shady videos?
Wow, thanks OP for this nice review. It is a good way to let us know more about G90. ;)
I haven't had chance to drive at night but here is a small clip of sunlight to shadow under bridges.
It adjusts to different lights almost instantly.
Very good.
Evening time screenshots.
G1WH has fuzzy right side. I need to check if my finger print or smudge is there.
G90: Pedestrian is clear.
20140724-g90-screenshot-7-jpg.6412
G1WH: Pedestrian is not clear.
20140724-g1wh-screenshot-7-jpg.6416
G90: Car is sharp and license is crisp.
20140724-g90-screenshot-8-jpg.6413
G1WH: Car is not as sharp and license is not as crisp as G90.
20140724-g1wh-screenshot-8-jpg.6417
G90: LIGHTENING... COOL...
20140724-g90-screenshot-9-jpg.6414
G1WH: LIGHTENING... COOL...
20140724-g1wh-screenshot-9-jpg.6418
G90:
20140724-g90-screenshot-10-jpg.6419
G1WH:
20140724-g1wh-screenshot-10-jpg.6415
I found that there is some blue tint on the top right corner of G90 videos, specially when the Sunlight is on that side.
G90:
20140725-g90-screenshot-2-png.6444
G1WH doesn't have blue tint but it's not that sharp in that area either:
20140725-g1wh-screenshot-2-png.6445
G90: Sharp in all areas:
20140725-g90-screenshot-1-png.6447
G1WH: Right lower corner not sharp even with upgraded Seezeus GT300 firmware:
20140725-g1wh-screenshot-1-png.6443
Sunny, pls download and test the updated firmware
https://www.sendspace.com/file/ke0m2p
Sunny: View attachment 6376
-- Yes. We changed from the second batch.
Upgraded to trunk: svn r328 and now it stays on with battery so one issue resolved even though battery doesn't last more than few minutes.
BTW, menu has 'Meter Mode Setting'.
What's best there? It was on center but I usually use average in my DSLR camera so should it be average?
I would like to know that what meter mode does really - does it matter what setting you choose?
Other thing Sunny, is your FPS now 25 or 30, you can check that from video resolution setting page?
Well in DSLR, metering is the way how light exposure is calculated.
It's different for portraits vs landscape pictures.
For dashcam video, I'm not sure what's best. This option was not there in other cameras so just asking what's the best.
Doreen should have the answer.
Overall bit rate increased from 15.8mbps to 19.5mbps even though video and audio bit rate is unchanged???
How's that possible?
May be I need to take longer video for proper data.
This properties is from Mediainfo.
As for files, here is before with initial firmware.
General
Complete name : F:\NORMAL\2014-07-23-17-34-30.MOV
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt
File size : 340 MiB
Duration : 3mn 0s
Overall bit rate mode : Variable
Overall bit rate : 15.8 Mbps
Encoded date : UTC 2014-07-23 17:34:30
Tagged date : UTC 2014-07-23 17:34:30
AMBA :
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Main@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 1 frame
Format settings, GOP : M=1, N=15
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 3mn 0s
Bit rate mode : Variable
Bit rate : 15.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.241
Stream size : 322 MiB (95%)
Title : Ambarella AVC / Ambarella AVC
Language : English
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : ADPCM
Codec ID : 11
Codec ID/Hint : Intel
Duration : 3mn 0s
Bit rate mode : Constant
Bit rate : 408 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Stream size : 8.76 MiB (3%)
Title : Ambarella AAC / Ambarella AAC
Language : English
With new r328 firmware: It's a short clip I did inside the room but that should give the idea.
General
Complete name : F:\NORMAL\2014-07-26-08-36-32.MOV
Format : MPEG-4
Codec ID : qt
File size : 40.0 MiB
Duration : 17s 217ms
Overall bit rate : 19.5 Mbps
Encoded date : UTC 2014-07-26 08:36:32
Tagged date : UTC 2014-07-26 08:36:32
AMBA :
Video
Format : AVC
Codec ID : avc1
Color space : YUV
Bit depth : 8 bits
Stream size : 31.0 MiB (77%)
Language : English
Audio
Format : ADPCM
Codec ID : 11
Duration : 17s 178ms
Bit rate : 408 Kbps
Stream size : 856 KiB (2%)
Language : English
Maybe it would be best to use every three metering mode choices for a day and then try to figure out what looks best to you, i think it might be different depending are you driving mostly in city or countryside, high buildings can change sunlight very fast.
Thanks for checking framerate, i had some strange FW that had set framerate to 25, now i loaded r328 again and now it is ok 30.
