BCHobbyist
- Jan 19, 2017
- Vancouver
- Canada
- A139 3Camera A129Duo-8WL A129Pro-4K A119V3 A119S-6Vk DCTeam
The Geko Gear website (tiny division of PAPAGO) released a new product for 2018 the S200 STARLIT Dash Camera. Features include 140 degree Lens with Sony Starvis Night Vision Sensor, 20 min Li-ion Battery, 2" LCD, Motion Detection, G-sensor, Parking Mode and more making this inexpensive Dashcam a great value. The official Firmware is limited to 12Mbs Bitrate, my Modified Firmware 15 & 18Mbs versions improve detail in complex scenes. This post will be updated with all future Firmware MOD releases to keep everyone up to date.
The GEKO S200 is a great entry level Dash Cam with excellent night vision and Full HD 1920x1080P resolution at 30fps saved in MP4 format, view my other S200 videos.
Download GEKO S200 RAW Footage + Modified Firmware > https://drive.google.com/open?id=1wy9QXmvusUi3Qwk2DpkaGdXiDPogHUcs
GEKO S200 Dash Cam - Specifications
Current Stable MODs for Public --- Updated December 8, 2018
Firmware Modification ID >>> MOD-2Bc = Bit Rate 12Mbps + IQ combination B + minor adjustments c
MOD-8Bc - - - December 5, 2018
FW96658A_MOD-8Bc_v1.08+18Mbps.bin
MOD-5Bc - - - December 5, 2018
FW96658A_MOD-5Bc_v1.08+15Mbps.bin
MOD-2Bc - - - December 5, 2018
FW96658A_MOD-2Bc_v1.08+12Mbps.bin
Beta Testing Setup = 3min clips, 1080P@30fps, EV=0, HDR on.
++ Beta MODs ++
Disclaimer: All BCHobbyist Modified Firmware is rigorously tested by DCTeam Members under all conditions world wide. These MODs are not official GEKO/Papago releases and considered Beta Firmware, I/we are not responsible for damage, loss, injury, or greatly improved image quality, use at your own risk.
Stable MODs - contains current tested modified firmware for Public use.
Beta MODs - contains versions being tested by DCTeam and Hobbyists.
Requested MODs - contains special request MOD combinations.
Download GEKO S200 Modified Firmware > https://drive.google.com/open?id=1wy9QXmvusUi3Qwk2DpkaGdXiDPogHUcs
Forum thread GEKO S200 Modified Firmware MODs Archive > https://dashcamtalk.com/forum/threads/geko-s200-1080p-dash-cam-review.37194/
How to load Modified Firmware:
NOTE:
Computers show or hide file extensions, if you see the .bin after download make sure it stays after renaming.
If you don't see .bin file extension no need to add it since its there but hidden from view.
If update fails or is corrupted the BootLoader still works.
To restore Dashcam, delete current FW file from memory card then copy official GEKO S200 firmware file to card then Power-On wait 60 seconds for Restart.
Browse all BCHobbyist WorkShop videos:
https://www.youtube.com/user/bchobbyist
Thanks for Subscribing and supporting my channel!
- 1728x1296 @30fps = 10Mbps
- 1920x1080 @30fps = 12Mbps
- 1280x720 @30fps = 7Mbps
- Novatek NT96658A Chipset
- Sony STARVIS Sensor
- 140 degree FOV Lens
- 2 inch LCD display
- 350 mAh Li-ion 20 min Battery (2hr recharge)
- G-sensor & Motion Detection & Parking Mode
- MP4 file format H.264
- Support 8 - 64GB Class 10 Memory Card
- quick release mount
- based on official FW v1.08.02
- changed Bit Rate from 12Mbps to 18Mbps for 1080P + 1296P.
- embedded MOD ID tag in MP4 file for quick confirmations.
- changed Bit Rate from 12Mbps to 15Mbps for 1080P + 1296P.
- changed Bit Rate from 10Mbps to 12Mbps for 1080P + 1296P.
++ Beta MODs ++
- DOWNLOAD the version and modification desired.
- COPY new FW MOD file to root of microSD card using computer.
- Safely Remove memory card from computer.
- Disconnect power to Dashcam, or press grey Power button for 3 seconds.
- Insert memory card with binary file into Dash Cam.
- Connect power to Dashcam wait 45 seconds for update to restart the Dashcam.
- Dashcam will restart on its own, do not disconnect power cable.
- Stop recording, then enter 2nd MENU and select FORMAT to delete all files, or to save previous video footage Power off and remove memory card to delete Firmware file using computer.
- Configure MENU settings Resolution, Date, Time Zone.
NOTE:
