- Jun 29, 2015
- China
- GIT1, GIT2
Latest and stable firmware, version number is "GIT1_V1.30_20160116", released on 16th Jan 2016.
http://www.gitup.com/support/firmware/git1/20160116/GIT1FW.zip
Change log:
1. Added: Control Led Status
4. Added:Configurable function for menu button while recording:ZOOM, support MAX 4X ZOOM
5. Added: Remote control working mode:
Regarding the remote control quick working mode, works as below:
Released new firmware today, version number is GIT1_V1.20_20151013.
Download link:
http://www.gitup.com/support/firmware/git1/20151013/GIT1FW.zip
Change Log:
1. Added: Support 720P 60fps
2. Improved: Auto exposure
3. Improved: Improved audio sampling rate to 44.1KHz
4. Improved: OFF front Red LED and ON Green LED then camera fully charged
5. Improved: Disable screen backlight after 1 minute while charging but enable backlight again if user press any button
6. Fixed: Recording with 3.5mm Female Microphone Adapter
7. Changed/Fixed: Text display issues -
Please do the following to upgrade the action cam
1. Download the firmware file
2. Unzip the file using available unzip programs, e.g. WinZip or 7-Zip
3. Open the file and copy the .bin file directly onto the MicroSD card root file
4. Insert the MicroSD card into the cam and power it on via a 5V/1A power source, e.g. cigarette lighter or power bank, it will start upgrade automatically.
5. While upgrading the photo status green light starts blinking(the light blinking slowly at the beginning, then blinking quickly), after the light stop blinking, it means upgrade is finished. (The whole process lasts about 30 seconds)
6. After upgrade, remove the SD card and delete the firmware, otherwise it will upgrade again when you power on the camera next time.
Earlier firmware can be found here.
To offer better support firmware, we just added a support section on product page.
Change log:
- a) All LED On (Turn on all LED)
- b) All LED Off (Turn off all LED)
- c) Front LED Off (Turn off front LED)
- d) Side LED Off (Turn off top LED and Wi-Fi LED)
- e) Back LED On (Only turn on the back LED)
- a)Low
- b)Medium
- c)High
- a)Standard
- b)Quick
- 1)Video Button: Start recording immediately in standby mode;
- 2)Photo Button: Take a video snapshot while in recording or take a photo in standby mode;
- 3)Power off Button: Stop Recording;
- 4)Wi-Fi Button: Enable/Disable Wi-Fi.
Download link:
Change Log:
