naturelover
- Jan 11, 2019
Thank you for the thorough reply.
I believe, stabilizer will work almost in the same way, but distortion correction for 170 degree lens won't be applied to image, so it may cause some "warp" in the corners of stabilized video. I'm going to add these settings for 170 FOV camera when next version of mod is released.
BTW, which video resolutions and functions are you using most with this camera?
I would suggest enabling effect Black&White for video (that is just original name of effect), it will prevent clipping of shadows and highlights during video playback in media player or youtube. It "squeezes" range of pixel values to fit into TV standard, where legal range of data is 16-240, and full range (0-255), which is used by default for video in this camera, is displayed incorrectly by media players, which are ignoring and clip all these out of range values, making contrast too high. No need for this effect for .JPG images, as full range is used as standard one, or in case video will be edited and editor allows to select input data format manually.As for the video and functions I'm mostly using 1440p at the moment and all other functions at normal/standard modes. High bitrate.
If I want to use it on board the bike I'm using 1080p at 60 fps for the buttery smoothness it provides.
That would be very interesting! I can hardly remember how my git2p recorded video with original firmware, and it would be nice to see if it has any improvements or what is worse now.I'm planning to do a video quality comparison between your modded firmware and the original firmware
Is it normal that Git2P 90° turn hot when it's in webcam mode ? | Git2 | 0 | ||
A | Macro Filter to fit on Git2P housing | Git2 | 0 | |
Best micro SD for Git2P | Git2 | 13 | ||
H | Git2P 90 FOV - latest firmware | Git2 | 7 | |
GitUp APP and New Firmware For Git2/Git2P/G3 | Git2 | 24 |
