GitUp F1: any good for dash cam use?
dirkzelf
Netherlands
http://www.gitup.com/home/78-gitup-f1-4k-wifi-action-camera.html
http://www.banggood.com/GITUP-F1-4K-WIFI-Action-Sport-Camera-FPV-Remote-Control-Sony-Exmor-R-Sensor-p-1187212.html
Ambarella A12S75
Sony Exmor Sensor IMX317 8MP
MINI USB
Power ON automatic recording
Digital image stabilisation
Loop recording
Low frontal profile
Flat, matchbox type housing
Cradle
Good Support (?)
WiFi, Bluetooth
TV out (optional cable)
Video Resolutions
4K HD video: 3840 x 2160P; 30fps
2160P HD video: 2880 x 2160P; 30fps
1440P HD video: 2560 x 14440P; 60/30fps
1080P HD video: 1920 × 1080P; 120/60/30fps
720P HD video: 1280 × 720P; 240/120fps
Storage MicroSD memory card with a Class 10 or UHS-1 rating required
Up to 128GB capacity supported
AOV 160 degree, abit too wide for my taste
Anyone?
TonyM
SG9665GC, A129, A129 Pro, Mobius 1 x2
You missed out electronic image stabilisation, and it supports loop recording. Some will say they prefer a capacitor to the li-ion battery. Not sure if it can auto-start on power input.
dirkzelf
dirkzelf
Netherlands
thanks, I read that of course, forgot to mention.... corrected.
Well, it starts when pushing the power button, so I guessed it would do the same when applying power to USB.... needs a check at GitUp. Be back soon...
Mtz
Nice place
Romania
Viofo A119. WR1. SGGCX2. GitUp.
If a camera is made by GitUp I expect to have car dvr features. But if @gitup consider that in car is too much heat for a 4K camera then maybe they will remove this option. I consider heat to be the biggest problem of a 4K dashcam.
enjoy,
Mtz
dirkzelf
dirkzelf
Netherlands
enjoy,
Mtz
yeah I know, but I would use only 1080p/60 or maybe 2.5k, but never 4k, due to space, heat and overkill for the function.....they could disable 4k for dash cam use only...?
Nigel
Devon
Gitup F1, A129, B1W, B2W
You might change your mind when you see the 4K video where you can read car plates at twice the normal distance! Also, at that distance they are only moving across the image at half the speed so have half the motion blur.
Gitup has posted that he has tested it in his car as a dashcam, didn't give us the test results though!
Mtz
Nice place
Romania
Then, why to buy an action camera to use it as dashcam? There are Viofo dashcams which can record as you want.
enjoy,
Mtz
dirkzelf
dirkzelf
Netherlands
Don't like Viofo's A119 shape so much ..... but I dó believe it to be a GOOD one.... :cool:
gitup
China
GIT1, GIT2
There is an option in system setting to choose to power on the camera or start recording while charger connected.
Also support quick capture feature, press the shutter button to power on the camera and start recording immediately.
kamkar1
Denmark
10 years, many dashcams
Will be interesting to see with that sensor used for sure, had it been with one of the other popular sensors i would have to say no on the grounds a dedicated dashcam with 1080p sensor would be a better option for dashcam.
But i am very exited to see what this camera can do in any kind of use.
estore009
Retailer
Shenzhen
China
B1W/B2W/Mini0906/DV688/B1M
If 2k resolution is clear enough to capture plate for dashcam,why need to rush into 4k resolution so quickly with possible heat problem?
dirkzelf
dirkzelf
Netherlands
I just got email from support@gitup.freshdesk.com that says:
"Hi, F1 cannot start recording automatically."
Which is the CORRECT answer please???
dirkzelf
dirkzelf
Netherlands
@gitup :
are all files ALWAYS stored in one and the same directory / map? Or does it create a new directory for each date / event / ride / flight?
TonyM
Sounds good, but I don't have a 4k screen to view it on.
TonyM
Dashmellow
Uncanny Valley (●_●)
numerous
Gitup commented on rcgroups that a 90degree version will be available - like the original Mobius A-lens. Too narrow??
It also seems to have a built-in lens protector that can be removed and replaced with a CPL. Nice linked up thinking about action and dash cam functions.
A 90 degree F1 would really appeal to me. Cool!
TonyM
I was tempted to pre-order, however I learned from the Mobius 2 that being an early-adopter doesn't always pay off.
kamkar1
Denmark
90 degrees are fine for me, both for dash and action use
Z F1 13
TonyM F1 15
TonyM F1 105
TonyM F1 0
D F1 17
