Mtz
- Nov 15, 2012
- Nice place
- Romania
- Viofo A329T (the best dashcam in the world!)
Not to move the camera down, but just the angle of view to point it a little lower. And be sure all screws from suction mount are tight.I can not make it lower as the heater elements are closer and the suction mount does not stick. At the moment it is pretty high up where the heater element has a wide enough space to accommodate the full suction cup and if I lower it then the mount only sticks for a few mins then drops off.
On my way home Video using a 37mm HOYA filter and plenty of country scenery.
maybe it was still processing when zerk viewed it. sometimes if you view a 1080p video quick enough after it's uploaded, you'll only see 320p or 480p.Now in 1080P ...not sure what happened with that Upload!
Nice work ljw2k, if you have time please upload some night videos aswell! Lightend highway and more dark places. Daytime video quality is really good, im going to get Git1 or Git2, as an dashcam.. Where did you buy Hoya filter? how much? π thnx mate!All fixed now and not sure what went wrong as I could only see 380p and 480p and it had been uploaded a few days so the processing would have well finished.
Thanks anyway for your help.
It is probably YouTube, I use my Git1 as a side camera and even when everything is passing at 100kph you can still read passing plates.The image is really sharp and looks great but when you get trees and shrubbery everything turns to mush. Is that a low bitrate issue?
Check out the blocking on the left and unreadable plates at 1:30
