Overall Camera experience was good until this happens
It is impossible to remove the camera from mounting bracket . Even if you press very hard to the unlock button you have to wiggle it to remove it if you are lucky it will be removed . And if it is stick it to the windscreen when you try to remove it , it broke .
It is not the worst part , Now the camera is not powering on . Also when you see the details there are wire sticking out from GPS mount which power the Camera , If you twist the GPS mount in wrong direction there is very fair chance that wire can break internally . Which there is no chance you can repair that . There are 3 contact point that power the camera and send the GPS data , I can guessing mine is broken from inside
