I purchased this camera approximately 1 1/2 years ago and noticed recently that the speed is not recorded on the video. I went through setup again but it still doesn't work. Any ideas as to what could be wrong?
Is there a possibility that you're pressing the MIC button while the camera is recording? That will turn audio recording on....Now I am having a problem with my audio. I can go into the menu and turn the audio off and several days later I will see the audio light on again. Is there a way to have it off all the time?...
Is the process for updating the firmware on the SGGCX2 the same as the SGGCX2PRO+?Mute should stay, are other settings staying set? Time zone or any other non default setting. If settings don’t stick something is wrong for sure. You can try updating the firmware.
