Green (wireless) LED now gone from bright to very dim. Why?
Geordie
Newcastle on Tyne
Blueskysea B1W
I've been running my B1W for about a year with no problems but recently the normally bright green LED which flashes regularly showing the cam is running in wireless mode, has become very dim. I've checked the car plug-in connection lead - OK; plugged the cam into my wall phone charger - OK; and connected to a power brick, again OK. In all three connections, the cam flashes a dim green.
I use a Samsung PRO Endurance 64 memory card and have tried others without solving this.
I've regularly checked the recordings and all is well here. The videos also have much improved since I fitted a CPL filter.
Anyone have a similar problem? Perhaps @estore00 might help?
Thanks.
SawMaster
SC
Mobius, G1W-S, G1W-HC,, G1W clone, B1W. VanTrue N2 Pro
LED's can go dim when they're failing, or if the power going to them is low. I'd lay odds on the first one since everything else is working OK. This sometimes happens with even the best LED's in the world but normally even the cheaper ones will last longer than the cam itself does.
Geordie
Geordie
Newcastle on Tyne
Blueskysea B1W
Hi Phil
That's what I thought too.
I wonder if @estore009 could advise what I should do?
estore009
Retailer
Shenzhen
China
B1W/Mini0906
Generally speaking, its led life is about 500,00~600,00 hours.
It should be the hardware problem with its Led light, and could you mind to send it back for a replacement?
P B1W 8
O B1W 21
Similar threads
