GS6000
hungarycam
Hungary
Hi,
I've just found a camera called "GS6000" on AliExpress, offered by several sellers. (for example: http://www.aliexpress.com/item/Original ... 56261.html)
Based on its data sheet, it seems to be the same as GS1000 orange menu, with little bit modified menu colors, higher sw version (SMH4.35.280712HB), modified (detachable) window holder and bigger display, and even 150%-200% price (158-198 USD) related to price of the good orange menus (120 USD).
Do you know sg about this "new" type?
Thanks, hungarycam
DashCamMan
Administrator
hungarycam said:
Hi,
Thanks, hungarycam
Hi hungarycam,
You are right the GS6000 is a new cam. It appears that the most of the Aliexpress vendors are taking preorders at the moment. However, in Russia, the Texet DVR-3GP is nearly identical to this cam. The Texet DVR-3GP was released this summer.
Note that the Texet DVR-2GP is the same camera just with a different case (the buttons are slightly different).
Dash Cam Man
DashCamMan
Administrator
The GS6000 / Texet DVR-3GP use the same Ambarella A2S60 processor as the GS1000. This camera has a much bigger screen at 2.7" and a different mounting system that lets you point the camera towards the drivers window (an important feature in Russia when dealing with corrupt police :shock: ). It also comes with an external GPS-receiver (SiRF Star III, 30-channel). The DVR-3GP comes with 256MB of built in memory. I'm not sure if the GS6000 does or not.
Apparently the DVR-3GP comes with firmware TXH3.35B.120712H (similar to the old orange menu). While this GS6000 appears to be similar to the new orange menu camera (SMH4.35.280712HB).
Here is a day video of the Texet DVR-3GP.
Dash Cam Man
DashCamMan
Administrator
Here are some pictures of the camera's size.
DashCamMan
Administrator
Here are some pictures of the camera mounted in a car.
DashCamMan
Administrator
There have only been a few reviews from owners so far. Some feedback:
- Larger screen and ability to rotate camera is nice for some owners
- Cannot place the camera high on the windshield due to the external antenna (see pics above)
- GPS catches satellites well
- Decent recording quality
- Unable to extract firmware using the autoexec.sh method
- One person reports overheating even with air conditioning on - runs it at 720p instead of 1080p to address this problem
Overall, I think the GS1000 Orange Menu is a better buy since it is much more compact and is cheaper. I personally don't see the need for a larger screen or the rotating ability. I haven't seen too many videos of these cameras but my guess is the quality will not be dramatically better or worse than the GS1000 orange menu.
Dash Cam Man
EP2015
China
On Aliexpress . other store have GS6000 original from E-PRANCE
http://www.aliexpress.com/store/product ... 05364.html
http://www.e-prance.com/index-catalog/r ... order.html
The Price is usd 137 Lower than Before
GS6000. GS1000 GS2000 original From one factory . they OEM for Russian market such as Texet etc
the Chip is same .
the Screen is bigger 2.7inch screen
Especially GPS logger . External GPS antenna. Catch GPS is more Stable and Faster
GS1000. GS2000. GPS logger . Sometimes is unstable
GPS receiver : SiRF Star III, 30-channel, TTFF
Built in Memory
DashCamMan
Administrator
the Chip is same .
Built in Memory
Thanks EP2015,
The lower price is good. For people who are looking for a larger screen, the ability to rotate the camera and stable GPS, this might be a good choice.
Dash Cam Man
DashCamMan
Administrator
Hi Stevin_12,
The GS6000 has an external GPS as shown below.
The GS1000 and GS6000 are quite similar. If you want a smaller, less expensive camera with built in GPS get the GS1000 Orange Menu from a reputable vendor. If you want a larger screen, the ability to rotate the camera and a more reliable GPS module get the GS6000.
Dash Cam Man
argonglobe
what is the hard-wired small camera shown in this picture? i am very interested in something like this...
Regards
Guy
DashCamMan
Administrator
Hi Guy,
I am not sure what that camera is. I haven't seen any HD cameras in that size/shape so I imagine it is an SD camera (480p). A similar styled HD one is the DOD GSE550 / GSE520. You can also fold it up when not in use making it very discreet. Unfortunately night quality is poor and the camera comes with a small internal battery.
[Broken External Image]:http://www.extrimcams.ru/data/images/dod-gse550-4.jpg
Dash Cam Man
kay188
DashCamMan said:
Why did you mount it like that?
The GPS is external, and from the pictures, you can mount it high, plug the USB power into the GPS slot, and then plug the GPS directly into the camera itself.
Mount it like this picture:
EDIT:
I see why you can't, because the camera is too close to the windshield and the GPS receiver is tall.
ALTERNATIVELY, you can buy a USB MINI extension cable, and place the GPS receiver somewhere else.
OR why don't you plug the USB power cable into the camera itself?
It will give you about 1" of more space to mount it higher.
kay188
I was going to buy the GS6000 to play with, but after reading the reviews, it's just a design upgrade.
Video field of view has been decreased by 10 degrees to 80degrees in 1080p, where as the GS1000 is 90degrees.
I'll stick to the GS1000 and buy the 3M Car DVR Bracket to replace the suction cup.
Vadikus
App Developer
Saint-Petersburg
Russian Federation
Hello GS6000 owners!
Could you check, if your camera works correctly in the last version of my program www.registratorviewer.com and send to my e-mail some examples of GPS file for my own analyze of format, because I have no one example from your dashcam.
overmerce
Rus
Hi to all. I just bought GS6000 with new PCU Ambarella A5S30. When arrived I'll tell you about.
