D
Deleted member 42788
Guest
Is there a way to hack the push-down event of the physical shutter button?
I'm aware of commands like {"msg_id":513,"token":1} and {"msg_id":514,"token":1}. The issue is that the VR firmware 1.0.179 will only sync the slave cameras by physically pressing the shutter button down. Otherwise, only the master will respond with the above mentioned commands and this is not ideal for my use case.
Additionally, the bluetooth remote will not pair with firmware 1.0.179 even though Yi documentation states otherwise and connecting via wifi achieves the same result as the above solution.
Also, how are all of you even figuring out what msg_id applies to what command? Is there some value that relates to 513 and 514, for example, in an output log?
Any help is appreciated. Thanks.
