Ive bought the new halfords cams and the backwards facing one is the wrong way. How do I flip it ? I cant read regs and signs anything.
. Would of thought this could be fixed with a firmware update?
I assume it is this one?: Halfords HDC-R Rear Dash CamIve bought the new halfords cams and the backwards facing one is the wrong way. How do I flip it ? I cant read regs and signs anything.
, makes the rear camera fairly useless really, can't understand how they didn't get that this would be a problem
Lots of video editors will let you "mirror" or "horizontal flip" the image. Or if you are overlaying the rear camera on the front as a picture in picture it often looks better mirrored since that is how you would see it when driving.thankyou, youre telling me! I thought this would be a bargain but I'm starting to doubt it
guessing there isn't a way of changing them post record? I will contact them to find out whats happening.
You can get video editors that can make a mirror image of your video. But is it worth the effort?thankyou, youre telling me! I thought this would be a bargain but I'm starting to doubt it
VLC can flip the image also
think I would return it as being "stupid" since viewing it via wifi on your phone is always going to look stupid unless they provide an app that flips it...
I don't know what the app is like, it may solve the problem, or maybe there isn't one - got to be worth a look before giving up, and report back!cheers folks it worked Ive managed to use that VLC but I didnt think it would be like this
not tried app that can be for another day, what others makes are available?
For the radio issue, you could try re-routing the cables so that they don't go near the radio antenna cable.im having the same problem!!! im also having another problem with my radio, i made a video... its acting weird and i dunno whats going on
Is there a fix for the flipping image problem or shall i take it back? it sounds like everyone is having this problem!!
Do you have a DAB radio with antenna in the rear window heater? If so then it may not be totally the camera's fault and you might have difficulty with any rear camera, try and mount it away from the heater wires, or fit a good quality DAB roof antenna.
I took this advice you offered in a previous post, and it solved the interference issue for me. There was a small metal box near the rear window that the DashCam cable was near until I re-routed the cable. Problem solved! Thanks!!For the radio issue, you could try re-routing the cables so that they don't go near the radio antenna cable.
F | Problem With Halfords HDC300 | Dash Cam Discussion | 2 | |
R | Halfords HDC300 Dash Cam | Dash Cam Discussion | 7 | |
Halfords HDC400 dash cam | Dash Cam Discussion | 5 | ||
I | Any recent feedback on Halfords HDC300 front-and-rear cam? | Dash Cam Discussion | 3 | |
I | New Halfords own dash cameras! | Dash Cam Discussion | 0 |
