I originally posted another thread with this identical question, but due to my inactivity, it never gained much traction. As for the question:
I currently have three dash cams (one generic, a A118C, and a G1W). Each dash cam would go to one car (all three cars are Prius's, two Gen 3's, and one Gen 2). I would like to hard wire them all, I do not need parking mode, just something so I can have an extra cig. socket just for the dash cams.
For now, I came across the idea of using a fuse tap, along with a female cig. socket to make this work. Here are my current list of parts:
I am not familiar with car electronics by any means, so I did want to clarify here if I am still missing anything. I also want to make sure that my steps are safe, and cannot cause any electric damages/fires. This is my current idea of how I should approach this, is this pretty much it?:
- First, I simply use the red wire from the female socket, and crimp it to the fuse tap
- Plug that fuse tap to where the current cig. socket is in the fuse box
- I then use a crimp connection (that circle shaped thing), and crimp it to the black wire, and ground it to some bolt.
- Success?
- What kind of fuse do I use for the fuse tap? would for instance 2 or 3 AMP work just fine, and then use the existing 10 or 15 (or whatever is currently being used for the cig. socket) in the second slot? I am kind of confused here. I know there is usually a 15 AMP limit for certain things, so I do not want to override anything here.
- I should be also plugging this into where a current cig. socket is being used, right? Or do I plug it into a different connection in the fuse box?
