winchester11
- Apr 15, 2019
- United States
Hello all,
I recently purchased an 129 Duo to replace my B1W. I have installed it using the 3-wire hardwire kit and tapped into the fuse box for power. I am confident that I have found a constant and switched power source and a good ground because I have tested them using other accessories. Unfortunately, I am seeing weird problems. In the past the camera has stayed powered on constantly but does not recognize when the ignition is turned on and off for a transfer to parking mode. Currently, however, the camera will not power on at all, regardless of whether the ignition is on. I have the power cable plugged directly into the camera, which is mounted on the GPS mount. I'm speculating that I may have a faulty hardwire cable, but I'm interested to see what your opinion is. Any help is appreciated.
