you can use that, there's another version power supply which is similar that is pre terminated with fuse tap and earth terminal if you don't want to muck about, same seller of the other power supply has them although I don't see it on their eBay listing
Is my best option is to tap the 15A CIG fuse?
When I tap it will it be ok since the fuse adapter only use mini blade fuse of 10A?
