Stationwedge
- Feb 23, 2017
I've been driving myself crazy with this and from what I've seen you all know a lot more than I do about wiring. Any help would be appreciated.
I hardwired a micro usb cable to one of the fuses in my car so it will only be powered with the engine on (the cigarette outlet is always powered). I used this fuse tap and this power / usb cable. When I first installed it, it worked fine - it powered on as soon as I started the car and off when I stopped.
The problem is, when I left it overnight and went to start the car the next morning, it didn't power on any longer. As I drove, I noticed that it would sporadically power on for a split second then stop. It could have been my imagination, but it seemed to do that only when I was applying the brake.
Further confusing me: I thought I might have had a bad ground connection, so I loosened the nut I had attached the ground to, detached the ground wire for a second, then put it back on the (same) nut and tightened. Then I started the car and the power worked fine. Then, after letting the car sit overnight, the next morning it didn't work, just as it didn't work before.
On top of that, last night I drove home (after it still not powering properly at any point), parked the car, let it sit for about 20 minutes, then restarted the car and it powered fine again. I turned the car on and off a few times to make sure. This time I hadn't done anything to the wires.
And then, of course, the next morning, it didn't power properly again.
What could be happening with this thing that makes it act differently based on the amount of time it's sat idle? It works after sitting with the engine off for a short period, but not overnight. As I said, I don't understand wiring or electrical systems well, so I can't even make a guess. Any ideas from you all would be very helpful. Thanks.
