I've been following
To hardwire A129 Plus. Everything works fine, but for some reason I started reading on the AMP fuse for the camera and it is suggested to be 5AMP max. Currently I'm using 10 AMP (both original and for the camera). Should I switch the camera one to 5 AMP? Per the video, the camera fuse is one next to the cable. I'm attaching photo of my fuse box installation.
One more question, because I'm about to hardwire my wife's car as well.
Fuse tap has 20 AMP max, is this per fuse or for both?
I'm asking because I'm able to find constant power fuse in her car with 10AMP (considering the fuse tap max AMP is for both) but it is ECU related, and per the video we should avoid critical fuse.
Tl;dr if I find fuse with with more than 20 AMP + 5 AMP for the camera is it safe? Or I should look for 15 AMP + 5AMP?
Sent from my SM-G991B using Tapatalk
