Hello. I'm about to order a QVIA T790, and would like to order an add-a-fuse kit at the same time. They come in many sizes (regular fuse vs mini fuse) Do most of you who hardwire tap into a regular size fuse? I have no clue what I'm doing.
According to the manual, there are spare fuses and a fuse puller on the underside of the lid for the main fuse box in the engine compartment. The interior fuse box is to the left of the steering column. I would pull a fuse on the interior fuse box to see what it is. There are so many different types nowadays, and you need to know what they are so you can buy the right Add A Circuit. The lid for the interior fuse box should have the layout of the fuses and what their purpose is. Unfortunately the online manuals don't seem to do that.
They are all the same size. Are these mini fuses?
This is what I pulled from the fuse box this morning. This is fuse # 29 (Fog light). They are all the same size. Are these mini fuses? That's the tip of my index finger for a reference. I also snapped a pic of the fuse box grid. Can someone chime in and recommend which fuse I should use? I would like to use parking mode when the car is off.
You can tap into a 10 amp fuse, but best to put in a 5 amp fuse for the side that goes to the dash camera.Thank you jokiin and Niko. I looked online and only found them up to a 10amp rating. Most of the amp ratings in my fuse box are 10 amps and up. Can I buy one of these from you?
You can select any Amperage fuse in your fuse box except the ones which are responsible for vital functions like Airbag, alarm, immobiliser, central lock.
I am in EU, so delivery will take some time ( usually 10 days ), but you better talk to @Pier28, he should have similar complete set US stock.
The way piggy back works is described below:
Niko can you tap a 5 amp fuse off an original 20/30 or so amp original fuse line, with no problems? It's the one question that I have never been able to get an answer about ?
I can't see why it would make any difference if the original line fuse is a lot larger then the tap in link. But I really don't know.
You need to understand that the tap a fuse creates an entirely different circuit for the extra fuse. The 20A fuse is still protecting the circuit it was protecting before. The 5A fuse you add on protects its own circuit, completely separate from the 20A fuse. You put it in the part that the wire comes out of, and you put the original fuse in the other socket.Niko can you tap a 5 amp fuse off an original 20/30 or so amp original fuse line, with no problems? It's the one question that I have never been able to get an answer about ?
tsouzee, please excuse my barging in, I thought you might like the answer to this question also.
Hi Paul, I understand that part, it was just putting a low amp fuse off a line with a high amp fuse that worried me, thanks for clearing things up for me.You need to understand that the tap a fuse creates an entirely different circuit for the extra fuse. The 20A fuse is still protecting the circuit it was protecting before. The 5A fuse you add on protects its own circuit, completely separate from the 20A fuse. You put it in the part that the wire comes out of, and you put the original fuse in the other socket.
