I don't use them, but member @Dashmellow knows and uses some excellent ones. All I know of these is to avoid the cheap ones which may be unsafe and are always highly over-rated.
Awesome that looks like a good fit. So buy 2, charge one while using other. Is there a way to set low bitrate to activate when i turn the car off? Is there any cam i can run in lowbitrate while off, that will return to good quality and notify me of events when i get back in?
Hi guys,
Looking to outfit a 2010 Nissan Rogue with 360 coverage (say for keying). Must haves: buffered parking mode, low light visibility. From browsing the forums, it seems like 1080 is the way to go for night instead of 4k. Probably a 2 2ch connected to a hardwired battery pack with an extra battery pack.
Any power supplies you would suggest? So what has a reliable lowbitrate mode since I see the A129 Pro Duo reliability is rated poorly on this site. I was looking at the A129 Pro, however I see it has had an unresolved duplicating frame issue for over 6 months. I like the A119 v3 and have even considered using two for back and front. I still want to do the sides, should i grab 4 A119 v3's? I would hardwire instead of power banks, im just unsure if it would mess up my car battery.Alternately (and the way most folks do this) is to use a aftermarket ciggie-plug PS with USB ports for power while driving, then switching the cable(s) there to powerbank(s) for parking. You still need the button-press to switch modes. Takes maybe 10-15 seconds if you have all this arranged and laid out well.
@HonestReview - Seriously man, have you read this thread carefully? You should do that so that you'd understand why the Zenfox won't work here. James is concerned about both sides of the car up close too, which no matter how you install it the Zenfox it isn't going to cover nearly as well as 2 dual-channel cams. And it's internal IR illumination will 'blind' the cabin cam from capturing exterior images then because of glass reflecting the IR back to the cam. Nor do we know if the Zenfox is reliable; after all it is brand new and you're being sent one for free to test that kind of thing for us.... Man, you're sounding like a 'shill' here We don't mind your thoughts or input, but please do keep up with what's going on before posting
Not when using this kind of powerbank but I think it switches automatically with the Neo.
To achieve normal driving recording needs only one power source which is switched on and off with the ignition key. This is usually a ciggie lighter plug or 2-wire HWK, but a 3-wire HWK can be configured to work this way too.
To achieve parking mode as well requires a wire connected to an always on source, and the other wire mentioned above. This takes a 3-wire HWK.
You'll see above that these are car power circuits, so to use a regular powerbank means that you're not tapped into the car any more- thus you lose the automatic switching between modes as well as power coming from the car. Thus you would have to switch between modes on the cam yourself (which I believe is one button press) and the powerbank would be your only power source. Alternately (and the way most folks do this) is to use a aftermarket ciggie-plug PS with USB ports for power while driving, then switching the cable(s) there to powerbank(s) for parking. You still need the button-press to switch modes. Takes maybe 10-15 seconds if you have all this arranged and laid out well.
There are also one or two good "pass-through" powerbanks which are fed by a HWK or ciggie-plug PS, and their output goes to the cam. These charge as you drive, and only feed power when their power source drops (engine turns off). Again you'll need to do a button press on the cam to switch modes. Closest you'll get to a Neo for ease-of-use.
If you're hardcore DIY, you could use a large AGM battery and 5V PS for cam power, and a battery isolator or relay system to allow it to charge while you drive. This will be my approach eventually.
You didn't see my secondary suggestion about Street Guardian / Viofo A129 + Interior Taxi Cam I take it?
I suggested Zenfox as a potential option if camera proves reliable. I'll find out when my sample gets here tomorrow about the quality of the image and how well it operates.
Yeah I havent mentioned wanting an interior cam once. Stop suggesting a product that hasn't even been released, let alone time to work out potential problems that went unnoticed. Go shill on your own "What should I buy" thread.
