[Help] Dashcam not recording much, if at all (in parking mode)
Buy a decent new battery sounds like the way to go
  • Like
Reactions: ANN
Car is barely 4 months old...
Also do not think it will solve the root cause of the problem (which is how far the PMP allows the battery to drain, I suspect).
Some cars have batteries barely big enough to save costs My VW only gets used about once a fortnight and has for over 2 years never failed to start.
Has a 650 CCA battery which is quite large for a car of its size.
  • Like
Reactions: ANN
You can always just use a battery guard that has different cutoff settings. You can set up a certain voltage for the winter and another for the summer. I'm talking about one like this one: https://www.ebay.com/itm/141107864386
  • Like
Reactions: ANN
I have decided to disable parking mode by turning off the multi-boot on my PMP. Not worth the drain and a higher cut-off won't fix the root issue of me not charging enough power through short distance driving and the draw in the winter even when the car is on. Thanks for the help though.
