I had learnt an expensive lesson today. I fried my dashboard front camera, but the bigger issue is i did not even know what i had done wrong. I did all my research like which fuse to piggy back on and which blade size to get for the add a circuit etc.
There was a small snap sound, and followed by burnt smell.
I hope someone can point out my mistake besides i should have gone to certified car mechanic instead of wiring it up myself. I thought i can be proud of my achievement but i have obviously failed big time.
The hardware kit i have used is thinkware. The red is the ACC or ignition switched wire which i have piggy backed on fuse 1 (Accessory 10 A) while the yellow is the constant or battery wire which i have pigged back on fuse 38 (Driver's side door lock 10A). I have also connected the ground wire to a bolt which is connected to the body of the car.
The add a circuit is a 15A Micro Fuse Holder Mini which i have used.
So what have i done wrong
https://ibb.co/ex8uPc
https://ibb.co/f7t5VH
https://ibb.co/nhGncx
https://ibb.co/f63iHx
