Help? How to Hardwire Thinkware f750 front and rear cam?
Cookey09
Hi everyone! First post!
I'm in desperate need of knowing how to correctly wire up the Thinkware f750 dash cam, front and rear. Rear I understand just plugs into the front via cable. No problem, I'm wanting to Hardwire it. But my car a 2014 Ford Fiesta UK. Doesnt have a live 12V when ignition off!? All fuses apparently turn off after 30minutes of inactivity with ignition off...
So this means I'd have to wire direct to battery? To enable the use of parking mode. My battery is In the engine bay.
I am fine for wiring one of the wires into an ignition switched fuse in the fuse box in the glovebox... This is done by using the tapAfuse technique? Correct me if I'm wrong please?
And one wire to a bolt on the metal chassis...
I'm wanting to Hardwire it before next weekend! But I'm unable to get my head around how I'm going to get a Continious power source to my DashCam to enable parking mode?
Please
Help?
Much appreciated and many thanks in advance.
Cookey.
Can you get a wire to the battery for the constant 12v?
I would be surprised if there isn't a 12v constant in the fuse box.
Not know the 2014 Fiesta does it have an alarm or central locking, if so there will be a fuse for it.
Let us know how you get on[emoji106]
