chelseajadex
Hi,
I'm in desperate need of some advice please. I have had my dash cam around 2 and a half years and have never had a problem with it.
Around a month ago i was completing updates on my laptop and the Nextbase software said a possible update is due on my dashcam so i went ahead and plugged it in. Once it was connected to my laptop it said it was already up-to-date so i put it back in my car.
Since then, i have had so many issues. It records for only two seconds and each time i press the record button it says that there is a memory error or the memory card is full despite having formatted it. I also cannot press 'mode' to watch video playback as it isn't recording and often says 'image error', on a couple of occasions there has been a static image on the screen and generally, it is unresponsive. I have removed the memory card and re-inserted it and pressed the reset button.
(I will try to take photos when the above happens again)
I would appreciate any help, suggestions or advice.
Thank you.
Thank you.
