WhoWhatWhyUserName
- Nov 22, 2018
- Australia
Hi guys,
I am after some help with hard wiring into a 2021 Hybrid Toyota CHR.
I have connected to interior fuse via B+ (spare fuse slot) and ACC (power terminal outlet) - both fuses confirmed with a circuit tester but after the car is turned off, the smartbox turns off after 3 minutes and then shuts down the dash cam. I even tried the fuses in the engine bay with the same issue.
It is a Mio/Navman smartbox wiring kit and dash cam.
I've bench tested the kit and dash cam and it is able to stay in parking mode for more than 30 minutes during bench testing, ruling out any possible fault with them.
Do the new Toyota's shut off any non standard accessory power after a certain time ? the B+ remains constant even after the dash cam is turned off.
Any suggestions what is causing it to shut off?
