DerrickDFromAsia
I bought a Vantrue N4 dash cam recently. It's a 3-channel dash cam(front, cabin, rear) so I'm wondering if a 128gb SD card is enough or should I get a bigger capacity SD card? What do you think?
Not sure what bitrate that camera uses? But you will probably only get about 3 hours on a 128GB card unless you turn the quality down, a 256GB would give much more chance of something not getting overwritten the same day. Note that memory cards wear out over time depending on the number of loops of the card, so a double size card will last double the lifespan, and they are normally less than twice the cost, thus bigger is better value in the long term as well as giving far more chance of not losing things before they are needed.I bought a Vantrue N4 dash cam recently. It's a 3-channel dash cam(front, cabin, rear) so I'm wondering if a 128gb SD card is enough or should I get a bigger capacity SD card? What do you think?
