HonestReview
- Feb 9, 2019
- Sweden
Where is Sweden?
The places I listed are "typical hotspots" for hot summers.
Apparently, you've never heard of Global Warming, where most places around the world are getting hotter these days. England usually never sees above 20C. Remember how London had record heat waves of near 38C? One member here stated he lived in Montana (far northern USA) a record 38-40C this past summer.
Unfortunately, mankind is destroying the planet. Maybe you should write mother nature a complaint?
If you mean 80°C ambient, recently I measured 61°C "inside" while 24°C ambient(in garage)... Are you sure it's going to survive the upping?
Spot on!
I cannot answer this question. Viofo is the only who knows the limits of their hardware. They may have been conservative and kept temperatures low to extend the life of their product. I.E. The Supercapacitors are rated for higher than 65C. On the other hand, 65C could be the highest normal operating temperature.
Which is why I stated two options.
1. Up the temperature and lower the cut off to 1-2C below that temperature if 65C is a soft limit and the hardware can do more.
2. Lower cutoff off by 1C, to allow camera to properly exist, before reaching 65C. Assuming 65C is the maximum the hardware / superacapacitors can handle.
