joe384
- Aug 29, 2019
- Essex
- United Kingdom
- 2 x DR590W-2CH, Cellink B
I'm currently using an Anker 2x 18W USB PD charger connected to 2x Poweradd 20,000mAh USB PD Powerbanks to get a total of 40,000mAh capacity and 36W charge rate - plenty for the supermarket car park, a 10 minute charge will easy give 2 hours parking mode and a full charge will give a full weekend with most dashcams. Also use a cheap voltage regulator (hardwire kit) to supply power while the powerbanks are charging and the outputs of the 3 are just connected in parallel. Not enough charge rate for 24 hour coverage, but more than enough for supermarket car parks.
The powerbanks cost me on average £4.10 delivered in ebay auctions, while a Cellink Neo with far less capacity than the two would cost £350 from Blackvue!
I always thought the charge rate referred to the output of the powerbank, I didn't realise you could fast charge the powerbank as well.
I'm not sure how you have done your setup? Are you saying you have spliced into the same usb cable for the dashcam with 3 input connectors?
