How to create a backup of the memory card?
Helmer
Netherlands
I can not figure it out
The memory card is full. I can save the images from the app on the laptop from 1 day. But then the memory card is still almost full.
How can I save everything from the card ??
Put card in PC make a folder called Blackvue backup Copy folder from card into the named folder job done.
If you only want what you have recorded Copy the Record folder across and play it with VLC video player or similar. You can also still use the Blackvue viewer Just point it to the location of that folder.
Then delete the contents of the record folder on the SD card. Camera will just record over record contents anyway so dont worry
