Absolutely no change to glarewhat did it look like before you rotated the CPL?
if it looks the same on or off check that the glass has been installed the right way around, if it's in backwards (rare but can happen) it won't have any affect at allhonestly, I can't tell any difference with the CPL filter on or off.
it's very rare to get one that isn't adjusted correctly alreadyAs i recall jokiin experienced this "faulty" CPL in the early days with one of his products, so he had to jump on a slow boat to china and crack the whip over the people at the assembly line
you see from the two pictures yourself there is virtually no difference. CPL filter is adjusted correctlyzero effect from the CPL would suggest that it isn't adjusted correctly
which would suggest it's not adjusted correctlyyou see from the two pictures yourself there is virtually no difference.
can see that it works, don't know which direction your glasses are polarised in thoughCPL filter is adjusted correctly
Night Glare | A129 Pro / A129 Pro Duo | 12 |
Similar threads |
Night Glare |
