In photo mode, I hope
1. to limit the shutter speed not slower than 1/250 second and leave ISO auto. Or,
2. to definitely set the shutter speed to 1/250 second and leave ISO auto.
Could anyone write complete autoexec.ash scripts according to above problems?
My Yi Camera's firmware version is 1.2.0
btw.
Will the "autoexec.ash" hack method permanently work during a whole turing-on, even after switching from a photo/recorder mode?
Why 1/250??
Anyway, this the 2. (iso auto, shutter speed 1/252)
I don't know if the 1) is possible...
Not at all!Thank you. Your scrip file works well on my Yi camera.
Not at all!
t ia2 -ae exp 100 0 0
sorry, there is no simple way for now. you have to test every custom ISO value for yourself one by one.Is there any ways to translate the exif value exposure time (1-2047) to fractional speed in seconds or viceversa?
Thank you.sorry, there is no simple way for now. you have to test every custom ISO value for yourself one by one.
I'm trying to record 2s Time Lapse with 100% jpeg quality. I try t cal -jqlt 100 and writeb 0xC0BC205B 0x64, but there is no result, even the while loop does not produce images larger than ~4MBSettings for capture in manual mode are kept in RTOSFS and override any changes done with autoexec script each time when you press the shutter button. So we can't change JPEG quality with the "t" command or with altering any memory bytes.
#Knee
t ia2 -adj autoknee 255
#ISO autoexposure gain
t ia2 -ae exp 100 Auto 0
#Auto WB off
t ia2 -awb off
#t cal -jqlt 100
#SET JPEG QUALITY TO 100
#writeb 0xC0BC205B 0x64
#noise reduction
t ia2 -adj tidx -1 0 -1
#disable sharpening
t is2 -shp mode 2
#file for sharpnes
t is2 -shp cor d:\coring.txt
#HDR 255 HDR, 1 High contrast
t ia2 -adj l_expo 191
#EV correction -1EV 64 -2EV 32
t ia2 -adj ae 96
sleep 10
while true
do
#t cal -jqlt 100
sleep 1
t app key shutter
sleep 1
done
C | How to increase wifi preview quality? | Yi Action Camera | 2 | |
Increase brightness | Yi Action Camera | 0 | ||
Brightness increase ? | Yi Action Camera | 0 | ||
L | Bitrate increase command line 1920x1080 30p | Yi Action Camera | 2 | |
Increase streaming bitrate ? | Yi Action Camera | 8 |
