Hello, I have a VIOFO A129 dual dash cam and the VIOFO 3wire hardwire kit. At the moment, I do not wish to use parking mode. Can I still use this hardwire kit?
Should i then only fuse tap the red wire, which is originally meant for constant on, to an ACC/ignition fuse so it turns on when I press my start stop button, and leave the yellow wire, originally for ACC, unplugged? Will this cause the battery power to drain and leak/waste through the unplugged yellow wire?
Or do I just tap both (red to constant on, yellow to acc) and just turn off parking mode from the setting? Will this prevent battery draining or will it still drain battery?
Many thanks!
Many thanks!
