DennisOlof
Hi.
Anyone know if the Gitup2 camera holder will be improved, I would like to see the same
kind of options you have on the SJCAM M10 and that one has a standard tripod mount
option on both the bottom and top of the unit.
This would be useful as you can not flip the image on the sensor, and you would also
be able to select how you place the camera with the a suction cup, either holding
in in the air from above, from windscreen in the car or supporting it from below, for example
the dashboard. All depending on where you use it. It would not take much to make
the changes, easy fix.
It might prevent you from changing the battery without removing the holder from the unit
but how often do you need to change the battery, I would say it would be of more use to have
these two mounting options than access to the battery compartment. If you need to
change it you can just remove the unit from the case anyway.
