RockThinking's schematic has a very expensive Audio-Out connection (pin #7)Does anybody have the pinout of the 2 different cables provided in the package?
(perhaps this is a faq, but i did not find the answer via googling.)
I love seeing pictures of original schematics, but most people prefer real-life pictures. HerrMueller, a member of RCGroups, posted an excellent pinout at http://www.rcgroups.com/forums/showpost.php?p=21446372&postcount=21
Combine RockThinking's schematic and HerrMueller's picture and you have everything you need.
From the manual, under Web Cam Mode:the DCIN5V will charge and power up the unit in recording mode (regardless what is set via the config file).
The VUSB will just charge the battery without powering on (if set accordingly)?
In other word's: I like to connect a "power bank" as charger while storing the camera in a pouch.
As i have wired it to DCIN at the moment it will start recording the inside of a black pocket (which is pretty useless), every time the contact is perhaps interrupted for a split second due to some body movement.
H | Hola, ayuda con mi Innovv C1 | C1 / C2 | 2 | |
C | Innovv C1 USB transfer issues | C1 / C2 | 3 | |
C | Innovv C1 USB transfer issues | C1 / C2 | 11 | |
Innovv C2 not starting consistently | C1 / C2 | 3 | ||
Using the INNOVV C1/C2 as a security camera | C1 / C2 | 18 |
