Tony lovelock
- Jan 18, 2017
- Hampshire
- United Kingdom
- Nextbase 422gw/Nextbase 212G & möbius C3 wide angle lens
Hi,
I own a möbius c3 wide angle lens action camera and it I've owned it for around 9 months now, and I've got an intermittent recording issue. I'm using a genuine tomtom 12v USB charger/socket that goes into my van cigarette lighter socket, and I'm using a 3 meter long (eBay) mini USB standard lead to charge/auto record. I've mounted the möbius on the rear of my van on the outside on top of my reversing camera bracket as I've got the möbius magnet mount attached. When I've plugged it in, it has started to record and then after about 5/10 mins it will go into photo mode? I'm using a 32gb Kingston genuine class 4 micro sd card to note. I can only assume it's the charging lead causing issues because the mini USB part going into the Connector to the möbius feels slightly loose where as if I plug in the short (supplied) möbius mini USB standard lead it clicks in better and feels slightly tighter... any thoughts or help would be appreciated!
