DerrickDFromAsia
I've been looking to get a new dash cam for my car and found there's 3-channel dash cam on Amazon. I'm thinking is it necessary to get a 3-channel dash cam? What do you guys think?
Both that Rexing V3 and the VanTrue N2 Pro have the cabin lens where it rotates only vertically, which limits it's usefulness in being able to turn it to the sides as may sometimes be desired to capture images there without disrupting the frontal view. The B2W cvabin cam rotates horizontally making this usage easy to do, and in fact is my favorite feature of that cam. I use that ability frequently both while driving and when parked. It's simply a much better way to do things rendering the other way obsolete
You must have one heck of a power source!I run my B2W continuously 24/7 in regular recording mode at a medium bitrate. Even with the summer heat here I have not had any problem doing this except for some slight focus shift on the hottest days, and that goes away once I start driving and letting a bit of wind cool things back down. It's not a method recommended by the manufacturer of any dashcam and it will void your warranty so you're on your own if you take this approach
Thanks for the information. I just checked the Vantrue N4 and it seems like a solid dash cam to meOnly working one that I've seen available is the Vantrue N4. It doesn't have a low bitrate recording mode for parking. Description seems to allude that it only has motion detection when hardwired.
https://www.vantrue.net/Goods/detail/gid/73.html
If you see the Zenfox T3 on amazon, I wouldn't buy it at the moment.
T | Are capacitors really necessary? | Dash Cam Discussion | 4 | |
Is Car Play/Andriod Out Necessary for Dash Cam? | Dash Cam Discussion | 10 | ||
V | Is reformatting really necessary? | Dash Cam Discussion | 8 | |
D | Is 4K really necessary for a dash cam? | Dash Cam Discussion | 35 | |
Why unnecessary for Dash Cam with Dual Cameras? | Dash Cam Discussion | 17 |
