country_hick
- Dec 10, 2014
One member on here did a nice job putting multiple 12 volt sockets together to provide power for multiple dashcams. Although this is a nice setup it takes up a lot of space. I started thinking. I now have 3 questions.
1. Is there a reliable usb only power converter box with 4 or more usb plugs available that would provide sufficient power for 4 or 5 dash cams?
2. Is there a simple way to transfer power from the cars battery to a usb power pack (or some alternative 12 volt power source capable of doing the job) without switching power cables around ny having one switch to go from car battery power to an auxiliary power source?
3. Would it be feasible to use a usb power pack to go from 5 volts to 12 volts to be reconverted to 5 volts for this power? Every voltage change in a step up or down in voltage wastes energy. I suspect the wasted energy in this conversion process would be to much for a pair of 2.1 amp 5 volt battery packs.
