- Feb 6, 2016
- New England
- Viofo, GitUp
They are the same camera. A119 is $90, A119S is $110.
Make sure the charger puts out at least 1A. Other chargers should work fine, they just need to put out enough power.Are these dash cams like require a specific charger? When I tired 2 diffferent car chargers the have problem staying on but when I try the viofo car charger it works. How come other car chargers don’t work.
I have a charger that puts out 1 amp and 2.1 amp. Other stuff chargers fine. I tried connecting just the viofo and even still it keeps turning on and off. I know it can’t be my charger because I tried 2 different chargers and 2 different usb built in charger.Make sure the charger puts out at least 1A. Other chargers should work fine, they just need to put out enough power.
12-volt cigarette lighter receptacle and plug, size A
12-volt cigarette lighter receptacle and plug, size B
- Receptacle inside diameter: 20.93–21.01 mm (median 20.97 mm)
- Plug body diameter: 20.73–20.88 mm (median 20.805 mm)
- Most often used in American automobiles
- Receptacle inside diameter: 21.41–21.51 mm (median 21.455 mm)
- Plug body diameter: 21.13–21.33 mm (median 21.18 mm)
inadequate
Even if writing on them or in the manual suggest otherwise, its like the 4K thing, people put buzz words on the product to make it sell better, which it probably do as we people are also bad shoppers.
Like I said the original usb mini works but if I try any other usb mini I get distorted color and for some reason the dash cam turns on and off.
DDPAI announces N5 Dual, new 4K dashcam with Radar | Dash Cam Discussion | 12 | ||
C | Uniden Dash View 50R | Dash Cam Discussion | 0 | |
P | Dashcam Parking Mode Without Hardwire | Dash Cam Discussion | 16 | |
D | M800 dash cam better than I thought! | Dash Cam Discussion | 3 | |
J | Does anyone else feel a bit uneasy driving without a dash cam? | Dash Cam Discussion | 10 |
