[ISSUE GOT RESOLVED YEAHHHHHHHHHHHHHHHHHHHHHHHH]Already going crazy. Never been frustrated like this.
yangren13
New york
My T330 arrived 5 days ago. I still cannot even connect the dash camera to the app and finish the settings, not to mention using it.
I have owned 4-5 dash cameras from various brands, including the Viofo A129 Duo, and NONE of them had any connection issues. The connection was as easy as breathing. How come the T330 just wants to FK me???
I have used my primary phone, an iPhone 15 Pro, for over 100 attempts, and no stable connection or livestream has happened. It was completely random, and the 3-4 times of successful connection only allowed me to take the necessary screenshots for troubleshooting.
Customer service asked me to use airplane mode, turn off Bluetooth, disable the app's cellular data, and reinstall the app, but none of them are working. Even if it did work, which dash camera on the market needs these settings that interrupt the smartphone's normal use?
I am also SO “Lucky” to have the issue when they are enjoy the gold week holidays and shutdown the technical support. They just release the product and gone. WHAT a waiting WEEK!!!!!
Today I tested using my iPhone 11, OnePlus 8T, Huawei Mate X5, and a Samsung to connect to the dashcam. They all failed and had the same issue. They just get stuck and disconnect after I press the ****ing "ENTER Dashcam".
Viofo, WHY are you FK me? What did I do to you?
Make sure Wifi is enabled on camera. Make sure you are connected to Viofo's T330 Wifi via the WIfi Connections. Open Viofo App and connect to camera. Also, blutooth can interfere so that is accurate. See if doing this manually works.
If not, it's likely a firmware bug Viofo needs to correct.
我之前卖给客户一个改长焦的119mpro,就是连不上,换了很多手机都连不上
I'm sitting here laughing at myself, wondering how to prove to the internet that I actually know how to use a dashcam. 😅
I really wish the solution was as simple as "Make sure Wifi is enabled," but I promise I'm already way past those basic steps. I've done all the manual setups, and it still just refuses to work. Honestly, I'm just feeling completely defeated by this thing right now.
I have officially lost my mind. I am completely broken.
Literally the day after I got my new car, I saw the news about the T330. Full of excitement, I waited a week for the launch event and ordered it on day one. A week goes by with no shipping update—turns out it was a pre-order. So I wait another week for it to ship across the ocean. It finally arrives, another week goes by, and I still can't use it!
Now I'm just sitting here holding this stick-shaped thing, completely clueless. I have never encountered a piece of tech so challenging in my life. It has successfully defeated every single smartphone in my entire house.
Every time I try to connect to the app, I swear the dashcam is mocking me. Its vibe is basically: "Give it your best shot, buddy. If you actually manage to connect to me, I'll call you Daddy."
I've spent the last three hours racking my brain, trying to figure out what horrible thing I did recently to deserve Viofo delivering this kind of karmic punishment.
I'm sorry you're having so much trouble.
As soon as it cools off in my garage, I'll make a connection / set up tutorial video for you.
We've been having a 100F heat wave for the past week, and we got another week to go.
-Chuck
-Chuck
Appreciate it, Chuck. But please no rush, because honestly, I know a tutorial isn't gonna work. I know my way around Viofo setups—I've owned the A119, A129 Duo, and 3 other dash cams. The T330 is not a SpaceX rocket; it shouldn't be any more difficult than the A129. The only difference between your tutorial video and my reality is that when we both hit the "Enter Dashcam" button, you'll get a nice livestream, while I get a spinning loading circle for 10 minutes followed by a disconnection notice.
I hardwired a Fitcamx into my CX-5 and perfectly managed the stealth cabling, so I'd like to consider myself somewhat of a skilled dash cam user. Yet here I am, completely unable to get dash cam protection for my new $62K Telluride. FML.
You've got 30 posts here. I don't assume ANYONE knows the basics, and start from square one. Clearly, Viofo made suggestions, too. However, you do note that I stated if these steps fail, there's likely a firmware issue. Viofo, like many dashcam makers, often suffer from them.
I'm still readily annoyed the A329T locks a video every time the camera is started or you shut the door. They did release a firmware fix per say (custom), but no general fix. I should honestly reload that one already.
The best thing you can do with the Chinese, is make a video showing them EXACTLY what happens. Most seem to only understand visual proof of a problem, before acknowledging one exists. Submit video to support.
Installing a Fitcam X is a lot different than a Viofo hardwire. Fitcam X taps into the Mirror for Power versus a hardwire kit / obdii. Basically, remove plastic cover, snap in place, plug in wire, put cover back on. Did you install a rear camera? That takes skill.
Also, FitcamX are poor dashcams overall for features and video quality.
I already switched to my native language in the support ticket. But right now, they're just enjoying their 7-day National Day holiday and the toll-free highways, experiencing the classic "people mountain, people sea".
View attachment 94541View attachment 94542
If you speak Chinese, that will help. Viofo has very limited English skills, and throw things into a translator. You've got to keep it VERY VERY SIMPLE with Visual Proof to get them to understand a problem when conversing in English. Even if you're a native Chinese Speaker, Visual Proof will get the point across. Viofo will run you throw the gauntlet asking you to troubleshoot. If you want to avoid writing a story, make a video of the problem, and show all the steps you've taken. It'll cut through the red tape.
Installing a Fitcam X is a lot different than a Viofo hardwire. Fitcam X taps into the Mirror for Power versus a hardwire kit / obdii. Did you install a rear camera?
Yes, I did install a rear camera. I fully acknowledged the poor features and video quality before I decided to switch from the A129 Duo. The main reason is that the interior plastic cover for the CX-5 sensor is curved, meaning the A129 cannot be perfectly leveled if I want to install it precisely in the middle. I simply chose to prioritize clean cable management over features and quality, at least until Viofo finally releases a solid barrel-shaped dash cam (excluding the T130, obviously).
If you speak Chinese, that will help. Viofo has very limited English skills, and throw things into a translator. You've got to keep it VERY VERY SIMPLE with Visual Proof to get them to understand a problem when conversing in English. Even if you're a native Chinese Speaker, Visual Proof will get the point across. Viofo will run you throw the gauntlet asking you to troubleshoot. If you want to avoid writing a story, make a video of the problem, and show all the steps you've taken. It'll cut throw the red tape.
Since we both use WeChat (the Chinese messaging app), I actually just requested a video call with them—kind of like FaceTime—so I can demonstrate the issue live. Now I just have to suffer through this incredibly looooong holiday week waiting for a reply.
I'm sorry you're having so many problems with your T330.
I don't know that I have an answer to why your T330 installation is having so many Wi-Fi connection issues. All I can say is that I've been successfully using my iPhone 15 Plus running iOS 26 [various versions] and an Android 10 device since June 2026 to connect to my T330 since I first received my prototype T330. I've not experienced the Wi-Fi connection issues that you've experienced. I have experienced the VIOFO Dashcam app not connecting/entering the dash camera when I have left my phone's VPN enabled. I saw that you stated you don't have a VPN or anti-virus software installed. Just make sure there isn't a VPN entry present you're not aware of in the Settings app "General > VPN & Device Management > VPN". Before I use my iPhone to connect to a dash camera, I have to go that Settings menu location and temporarily disable the "Device VPN" I have installed on my iPhone.
I see by the S/N you listed in a previous post, that your T330 is a 2-channel unit which has a rear camera. I'm sure this is already true, but make sure the rear camera cable is plugged into the "REAR" coaxial cable port on the T330 front camera unit. As a test, you might try disconnecting the rear camera cable at the T330 front camera to see if you can connect to the T330 as a 1-channel dash camera.
If you've used the same memory card during this entire problem and you have a different memory card to use for testing, you might try using a different memory card to make sure the T330 is not getting hung up on writing video content to the memory card causing problems in other areas. Not likely, but worth eliminating as possible issue.
This shouldn't make any difference, but have you tried turning on the T330's Wi-Fi hotspot by a voice command and using the Wi-Fi button? Try each of them to see if it makes any difference.
My Configuration:
  • Dash Camera: T330 3-Channel [Front + Rear + Interior]
  • T330 Firmware: V1.0_260910
  • Memory Card: VIOFO 512 GB
  • iOS VIOFO Dashcam App Version: 2.2.3.7
  • Mobile Device: iPhone 15 Plus [MTXX3LL/A]
  • iOS Version: 26.7.1
I just went out to my car to use my iPhone to connect to my T330 3-Channel dash camera. The connection process went smoothly. I was able to see a live view of each of the three cameras. I was able to enter the settings portion of the app for the T330 without error. When I exited the settings section, it successfully created a new live view session with the T330.
I hope you find a solution to your problem very soon!
My Configuration:
Thank you for your information.
For the VPN, even if my iPhone 15 Pro has a hidden VPN in the setting, it impossible I have the VPN all across the iphone, Huawei, Oneplus, Samsung phone that I have tested.
I haven't have a chance to hook up the rear camera.
I have a 128GB and 512GB memory card, all from Viofo brand.
Each time you tried a different phone did you;
1.) Perform Factory Reset / Default Settings (long press REC + O buttons simultaneously for 5 seconds).
2.) Delete VIOFO APP from Smartphone and re-install
These two things usually work for me.
Next do this;
Turn Off BP60
Turn Off Car play
Turn Off any other Wi-Fi & Bluetooth signal in the area
Prepare iPhone connection sequence 📱
Turn Off Airplane Mode ✈️
Turn On Wi-Fi 🛜
Turn On Bluetooth ᛒ
Turn On Cellular Data 📶
Turn On Location Services ↗️ (Privacy & Security) ✋
Turn Off VPN 🌐
Next do this;
Turn Off BP60
Turn Off Car play
Turn On Wi-Fi 🛜
Turn On Bluetooth ᛒ
Turn Off VPN 🌐
Thanks Chuck. The Factory Reset resolved the issue.
The point is the Factory Reset
Factory Reset Factory Reset Factory Reset Factory Reset Factory Reset Factory Reset Factory Reset Factory Reset Factory Reset Factory Reset Factory Reset Factory Reset Factory Reset Factory Reset Oh my God.
