Issue with Cellink Neo EXT7
SirCozak
Hi Everyone
I'm looking for some advice regarding a Cellink Neo 7 Ext battery pack. I have Neo 6 battery pack as my main unit, purchased about 6 months or so ago. It is hardwired in and set to 9amps, and that works perfectly fine with it charging up when the ignition is on and then going into parking mode when the engine is off.
I recently wanted to extend my parking mode runtime so I purchased the Neo Ext 7 expansion battery to add to my Neo 6. However there appears to be an issue in that it simply doesn't charge. I was thinking at first that it was faulty and was planning on returning it for a replacement. However I have noticed some differences between the website images of the Neo 7 Ext Battery and the unit I have received. On the website images the Ext7 has two yellow input/output connectors only, and these match the single yellow ext batt connector on the main Neo 6 unit. However on Ext7 battery pack I have received it has an orange connector on the left and the yellow one on the right. It also has a usb port and a charging/discharging indicator led in the middle. The orange connector is actually 3 pin, with the third pin being in the place where the notch at the top of the yellow connector usually sits. So it appears to be of a completely different design. The connector cable that came with the Ext7 also has a 3rd cable, so clearly this third pin is meant for something. I am wondering if the Ext7 has been redesigned and is not compatible with Neo 6 I purchased 6 months ago due to this 3rd pin. The Ext7 also didn't come with instructions, so I'm unsure which connector should be connected to the main unit, although the charge light doesn't come on regardless of which one I connect it up to.
Does anyone know if this seemingly redesigned Ext7 works with the Neo 6 that has the yellow ext batt connector? I'm trying to decide if I should just get a refund as I don't want to request a replacement to then just have the same thing happen again due to incompatibility.
Any help is most appreciated!
maus1975
Rotterdam
Netherlands
Hi,
I've had serious problems with the old cellini neo ext7. I've had 2 old versions, who didn't work with mij neo6. De new version was send to me almost full with juce.
On the new version you will also vind a on/off switch. I assume you set the switch to on? When I switch the battery on the led was turning on imidiately.
My new ext7 is loading with and without the 3rd pin cable. Is can even load under 5 amps. The new cable also fits in my older neo6.
Good luck.
S
SirCozak
There is no on/off switch on mine at all. It's got no charge at all, I removed it from the car earlier and plugged my mobile phone into the usb port to see if it would charge and nothing.
Below is what it looks like, note the metal pin on the orange connector along the top. The yellow connector has not such pin, and the notch at the top is just plastic. If anyone has the version below working with a Neo 6 with the yellow ext batt connector please let me know.
maus1975
Rotterdam
Netherlands
I have a new version, just got in today. Cellink is delivering them this month. I've had 2 batteries. Both didn't work, just like you. Problems with the first start. The dealer delivered me this new version.IMG_20210412_225155.jpg
S
SirCozak
Thanks, mine lacks the switch, perhaps this one I have is just broken. Can you confirm if you have yours connected to a Neo 6 that has the yellow ext batt socket?
Tips
Scotland
I am having issues as well with these batteries. I have 2 EXT7+ batteries and the LED blinks red then nothing when I plug the cable into it (either port). The ones I have received both came with the orange port and the connector with 3 cables. They are connecting to a EXT6. I thought maybe dodgy LEDs on the batteries but when I set the app to the higher capacity the camera dies at 50%. I have tried plugging the EXT7+ into a home charger which powers the EXT6 fine but get the same result with the LED flashing red for a split second.
I noticed the unit posted above as a on/off switch which none of mine have.
S
SirCozak
Mine was exactly the same, red led flashes for a split second when the charge cable was disconnected. I sent it back in the end and it was confirmed as dead. Decided to get a refund and wait a bit to ensure when I do get another it's the one with the switch as per the above which seems to be of a newer design.
maus1975
Rotterdam
Netherlands
Hi, I can confirm that I have a Neo6 with a yellow ext battery socket. I also can confirm that the new version of the ext7 works flawless
Tips
Scotland
Received today from Amazon UK directly.
EXT7+ with on/off switch which after 2 previous batteries being faulty i have got lucky and got the latest batch
EXT7+ and Neo6 both working as they should.
Even the cellink support in UK (NWX) are clueless.
Firstly they never knew 6800Mah batteries existed.
They never knew about a new batch with on/off switch.
They had my neo6 and ext7+ in their office and claimed worked fine blaming operating temperatures etc etc, when the car electricians who installed my setup confirmed more than once the ext7 was dead. Luckily I bought direct from Amazon.
Zed333
London
Hi guys, hope someone can help, I’ve decided to return my ext7 pack, as above I called up cellink support in UK (NWX) and as above they were clueless and not much help, I’ve decided to return my ext7 pack as non of the led lights work so I’m assuming mine is defective to however I’m finding it near impossible to find a carrier to ship the lithium batteries as they are “dangerous goods” can someone advise on a carrier that will ship these back to Amazon
Amazon.co.uk Customer Returns
Amazon Way
Dunfermline
Fife
KY118ST
Please your help would be greatly appreciated
jokiin
Too many ¯\_(ツ)_/¯
airfreight is a problem, did you check with the post to see if they offer a ground service only to that destination?
next option is talk to Amazon again, they obviously had a carrier that would ship it to you
Tips
Scotland
Amazon Way
Dunfermline
Fife
KY118ST
Just send it via royal mail. That's what I done with mine. Just don't put the battery warning label on box.
Zed333
London
next option is talk to Amazon again, they obviously had a carrier that would to ship it to you
Hi, yes spoke to Amazon customer services on a number of occasions
They’ve sent me a number of carriers but every time you read the terms and conditions it lists they don’t ship
So now I’m going round in circles and trying to find out what is the best way forward
gabilondo77
Torrevieja
Spain
Viofo A129 Duo,Viofo A129 Pro Duo 4K
I've just received yesterday the EXT7 battery from Amazon Spain..It came completely discharged and is the old model 6600mAh with two yellow connectors(no switches,no USB plug)..I have charged it in my house connected to the main Neo 6 unit,then connected them in my car to A129 Pro Duo cameras and it shows between 48-50 hours remaining(in low bitrate parking mode FHD+FHD)..I think I'm good to go.20210626_192046.jpg
