SnitserNL
- Oct 18, 2013
- Sneek
- Netherlands
- DOD LS460W
Yesterday I received my newly bought LS460W. As I had an old dashcam, a GS5000, using a 32Gb class 4 MicroSDcard, I tried to use this memory card in the LS460W.
Yesterday it all worked fine. Only, when looking at the footage using Registrator Viewer, I noticed that all recorded files were locked.
Today I tested my dashcam again with the screen on, and I noticed that the lock-icon appeared in the screen with every G-sensor setting (High-Middle-Low). Even when the car was not moving at all the files were locked. Only when the G-sensor setting set to Off the current file would not be locked.
When coming home I noticed that most footage hadn't been written to the memory card. Only a few minutes of the 1.5 hours that I was driving were taped.
Now I know that according to the manual I should be using a class 10 card (the box says it should be a class 6 or 10), max 32Gb.
But, could the problems described above could be caused by the memory card. Or is it more likely that the dashcam's G-sensor isn't working properly?
What card is the best memory card to buy for the LS460W?
Greetings from the Netherlands,
SnitserNL.
SnitserNL.
