dirkzelf
- Nov 16, 2012
- Netherlands
Some IQ issues can be solved by changing Menu settings.
Flashing or auto brightening can result from DVR adjusting to either dark scene or bright object - toggling HDR on or off may reduce that effect.
DVR turning off then on or restarting could be over heated microSD card or loose in slot - try different memory card that is heat resistant. When using high Bitrate MODs which create large MP4 files its best to use memory card with faster than 20MB/s write speed. Cards with 60-90MB/s Write speed may help reduce random crashes or prevent file corruption, just a suggestion.
I don't own this Dashcam so can't witness the issues directly. Troubleshooting device and firmware takes time, it would help to know if these issues occur in all official FW versions for all owners.
The flashing only occurs in 1080p/60 setting during Daylight recordings, it's the road surface right in front of the truck that shows the flashing, I suspect others don't notice that in their recordings so much, because my camera in the truck is flat to the windshield and it has no nose, so it records much more road surface close to the truck than in a regular car. I don't see that flashing in night recordings which are in 1080p/30 in HDR setting.
However, both settings I use WDR ON so tomorrow I can turn that to OFF for the daytime recording to see if that helps, although WDR doesn't create that kind of flashing in my other dashcams, just an observation, I don't know if that's significant.
I use SAMSUNG EVO U3 Cards that write 90mb/s. Also I have tightened the card slot a little so that I'm sure the card is really snug fit ensuring no contact loss. The stop / start issue only occurs after looping has started (after the card is full) .
It has been mentioned that it could have something to do with power issues. I haven't found any proof for that yet I'm afraid.
